About a week ago I noticed that food was defrosting in my freezer. the temp control was set to 3 (factory setting), so I turned it to almost 5 and cleaned out freezer to allow better airflow. This seemed to work and the next day, everything was frozen again. I turned it back down to 4 to see if it would keep frozen and it did. Yesterday, everything was defrosting again. I turned temp control to 5 again and this time it did not help, I turned it to 6 this morning and it is still slowly defrosting. I can hear it running though. I am emptying freezer completely tonight since I don't want to have to throw it all away. Any suggestions on what to check? The door seals are all fine. HELP.
Groups: APP Team
Hi. First check if the compressor is running. If yes - remove the rear panel in the freezer and check the frost pattern on the evaporator coil. It should be covered evenly. Make sure the fridge is running, both fans:evaporator and condenser are running too. Here are the breakdown diagrams and http://www.appliancepartspros.c...gidaire-frs26kr4cq0.htmlPost results. Simon.
by the time I received this reply, freezer had defrosted all over my wood floors. :( so obviously, there was no frost. I had already moved all the food so no loss there. Compressor seems to be the culprit. thanks.
Groups: APP Team
