muegge99
#1 Posted : Wednesday, March 27, 2013 4:27:13 PM(UTC)
muegge99
My dishwasher heating element is not heating at all. I have tested the continuity of the heating element on my analog multimeter and get a reading of 0 ohm. Does this mean I should replace the heating element? Thanks in advance.
#2 Posted : Thursday, March 28, 2013 1:50:48 AM(UTC)
Parts for Whirlpool DU810SWPU3 Dishwasher - AppliancePartsPros.com
Sounds like you may have a problem reading the meter.
If the reading is 0 ohms you may be on to high of a meter scale.
The heater should be 30 ohms or so.
Zero ohms is a dead short so the heater would blow your circuit breaker.
From the tech shet you will see that there is a thermal fuse (item 26 in the Tub Parts section) in line with the heater.
It should be o ohms.
File Attachment(s):
DU810.pdf (215kb) downloaded 13 time(s).
kf6irk
#3 Posted : Saturday, April 13, 2013 12:41:01 PM(UTC)
kf6irk
Our dishwasher apears to have hot water for washing, but no dry heat.
Does the heating element heat the wash/rince water, or does it only come into play during the drying cycle?
I guess the first things I'll check is the fuse and the resistance of the heating element?
This is a Whirlpool DP6000XRPO (in a portable cabinet)
#4 Posted : Sunday, April 14, 2013 4:55:09 AM(UTC)
Here is the operators manual
https://www.whirlpool.com/digita...20Guide%20-%20304273.pdf
[COLOR="Blue"]Does the heating element heat the wash/rince water, or does it only come into play during the drying cycle?[/COLOR]
Depends on the cycle type, see page 4 in the manual.
Parts for Whirlpool DP6000XRP0 Dishwasher - AppliancePartsPros.com
[COLOR="Blue"]I guess the first things I'll check is the fuse and the resistance of the heating element?[/COLOR]
That would be a good place to start.
Whirlpool Heating Element Not Working (Dishwasher Repair)
by sfuller 12/4/2010 10:11:17 AM(UTC)
