Hugey
#1 Posted : Monday, April 1, 2013 1:36:59 PM(UTC)
Hugey
Dishwasher was dead.Diagnosed a bad timer. Replaced it, and it worked a few minutes, and shut down again!
Simon / APP Team
#2 Posted : Tuesday, April 2, 2013 10:24:32 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please provide more info. What was the original problem? What makes you think it's the timer? What do you mean "shot down"?
Simon.
Hugey
#3 Posted : Tuesday, April 2, 2013 10:49:41 AM(UTC)
Hugey
Simon,
Thanks for responding Original problem was that it completely died. Circuit tester showed no reading going out of the timer, so I replaced it!
And it worked for 10 minutes, and then shut down completely again, meaning it stopped working all together, and the electrical outlet is still live. So I am thinking the motor is old and it seized up! Maybe it took out the new timer too? what are your thoughts?
Rob
Simon / APP Team
#4 Posted : Tuesday, April 2, 2013 1:34:22 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the latch mechanism, the latch switch.Make sure you are getting the 120VAC through the switch to the timer. A lot of times there could be a bad connection in the junction box behind the toe panel(on the right).Do not use circuit tester, use a multimeter.
Post the results.
Simon.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
