rebecca46628
#1 Posted : Tuesday, March 26, 2013 3:29:36 PM(UTC)
rebecca46628
My dryer is about five years old. I have never had a problem with it until last week when it randomly stopped working.
I can hear the timer ticking. The light goes on inside the drum. When it is on wrinkle release mode, it turns on every few minutes like it is suppose to but it won't actually run to dry clothes.
So far, I have tested:
thermal fuse, start switch, door switch, buzzer, time motor, and about any thing else I could find.
Any idea what else I should try? Someone said it could be the relays but I can't seem to find them. Help????
Simon / APP Team
#2 Posted : Tuesday, March 26, 2013 4:29:18 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
It sounds like you may have the bad timer.
Post the model and the serial numbers so I can find the parts.
Simon.
rebecca46628
#3 Posted : Tuesday, March 26, 2013 4:38:18 PM(UTC)
rebecca46628
MOdel Number Appears To Be Med5740tqp0 With The Serial Number Mw1010956. The Timer Says Its MoDel Number m460-G.
Is It Likely To Be The Timer If I Still Hear It Ticking, Though
Simon / APP Team
#4 Posted : Wednesday, March 27, 2013 8:44:38 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Open the control panel and use the multimeter to check the timer.
Set the timer to Timed - Regular and check continuity between T-WB, BK-BU, BK-R, T-W.
They all should be closed. If not - replace the timer
Part number: AP3859587
Post the results.
Simon.
rebecca46628
#5 Posted : Wednesday, March 27, 2013 1:53:02 PM(UTC)
rebecca46628
One Of The Circuits Is Not Closed.Looks Like We Have The Problem! Thanks!
Simon / APP Team
#6 Posted : Wednesday, March 27, 2013 2:07:55 PM(UTC)
Simon / APP Team
Groups: APP Team
You can check the timer by jumping those two open contacts and see if the dryer will work.
Post the results.
Simon.
rebecca46628
#7 Posted : Thursday, March 28, 2013 8:44:38 AM(UTC)
rebecca46628
I spoke to soon. I installed the new part and still no luck...
#8 Posted : Thursday, March 28, 2013 12:16:27 PM(UTC)
Hello,
What happen after you replaced the timer?
Is it completely dead?
Does it make any noise?
Have you tried different cycles?
