2 Pages<12
#11 Posted : 12 years ago
What is wrong with the circulation pump?
pmat
#12 Posted : 12 years ago
pmat
Nothing that I know of, just wondering if a damaged impeller could be the cause of the excessive foaming and odd sound. I am going to have a look at the impeller just for the experience of taking it apart.
-Paul
#13 Posted : 12 years ago
No, I don't think so.
pmat
#14 Posted : 12 years ago
pmat
You are correct, I looked at the impeller and it is fine. One thing has me wondering: the dishwasher model 9915uc/U11 has no sound insulation blankets as is depicted on some of the online repair videos that I have seen. The tub has some dark hard sound dampening directly affixed to it but no "blankets" It has metal side covers but no insulation between the covers and the tub. Also no sound dampening in the front on the bottom other than what is attached to the front kick plate. Is this normal or could someone have discarded the blankets?
https://lh5.googleusercontent.co...w497-h373/dishwasher.jpg
#15 Posted : 12 years ago
Looks like someone have discarded it.
- The door sound insulation plate Part number: 351934
Part number: 351934
- The tank insulation Part number: 366495
Part number: 366495
pmat
#16 Posted : 12 years ago
pmat
I do have the door insulation panel. The tank insulation part number 366495 says its not compatible with the shu9915uc/u11. Would it work anyway?
#17 Posted : 12 years ago
Yes, it would. I found the part number as the search result by the model number you posted earlier.
2 Pages<12
