2 Pages<12
#11 Posted : Tuesday, March 12, 2013 2:10:31 PM(UTC)
What is wrong with the circulation pump?
pmat
#12 Posted : Sunday, March 17, 2013 3:55:09 AM(UTC)
pmat
Nothing that I know of, just wondering if a damaged impeller could be the cause of the excessive foaming and odd sound. I am going to have a look at the impeller just for the experience of taking it apart.
-Paul
#13 Posted : Monday, March 18, 2013 1:12:49 PM(UTC)
No, I don't think so.
pmat
#14 Posted : Tuesday, March 19, 2013 3:15:49 PM(UTC)
pmat
You are correct, I looked at the impeller and it is fine. One thing has me wondering: the dishwasher model 9915uc/U11 has no sound insulation blankets as is depicted on some of the online repair videos that I have seen. The tub has some dark hard sound dampening directly affixed to it but no "blankets" It has metal side covers but no insulation between the covers and the tub. Also no sound dampening in the front on the bottom other than what is attached to the front kick plate. Is this normal or could someone have discarded the blankets?
https://lh5.googleusercontent.co...w497-h373/dishwasher.jpg
#15 Posted : Tuesday, March 19, 2013 3:49:40 PM(UTC)
Looks like someone have discarded it.
- The door sound insulation plate Part number: 351934
Part number: 351934
- The tank insulation Part number: 366495
Part number: 366495
pmat
#16 Posted : Tuesday, March 19, 2013 5:39:32 PM(UTC)
pmat
I do have the door insulation panel. The tank insulation part number 366495 says its not compatible with the shu9915uc/u11. Would it work anyway?
#17 Posted : Tuesday, March 19, 2013 5:53:44 PM(UTC)
Yes, it would. I found the part number as the search result by the model number you posted earlier.
Guest (5)
2 Pages<12
