JWarner
#1 Posted : Sunday, April 19, 2009 6:14:41 AM(UTC)
JWarner
My washer stuck in rinse/spin cycle and overfilled the barrel. It flooded our house. Is the timer replacement a fix?
TechnicianBrian
#2 Posted : Sunday, April 19, 2009 7:38:04 AM(UTC)
TechnicianBrian
The pressure switch (AP3019703) inside the user panel is what determines the water level. Check the clear hose that runs to the switch for a hole or tear and if it's in good shape, replace the pressure switch.
JWarner
#3 Posted : Sunday, April 19, 2009 3:24:06 PM(UTC)
JWarner
If I replace this switch, should I still replace the timer? I think that my original problem will still be there unless I change the timer.
Thanks again, Jeff
TechnicianBrian
#4 Posted : Sunday, April 19, 2009 3:42:54 PM(UTC)
TechnicianBrian
Thanks again, Jeff
If the timer is not advancing, then yes replace it. But if it is just stalling and waiting for the pressure switch to close, then no. The timer will pause when the water valves are on and will wait for the pressure switch to close to start moving again. So if the timer only stalls at the point water is entering the tub, I would think the pressure switch is the only part needed.
Whirlpool Timer issues? (Washer Repair)
by smev123 6/7/2015 7:30:40 AM(UTC)
Dryer timer issues (Dryer Repair)
by PuzzledKenmore 10/11/2014 9:17:58 PM(UTC)
Timer issues on older KitchenAid (Whirlpool direct drive) (Washer Repair)
by jz78817 4/1/2013 3:10:41 PM(UTC)
Timer Issues (Dryer Repair)
by fil2 11/20/2012 3:28:35 PM(UTC)
Kitchen Aid Dryer (timer issues) (Dryer Repair)
by iMayco 4/24/2012 10:55:22 AM(UTC)
Maytag Timer Issues? (Washer Repair)
by andrewetta 12/12/2011 7:52:53 AM(UTC)
Kenmore washer timer issues? Help please. (Washer Repair)
by ffspiel 6/5/2010 9:17:38 AM(UTC)
Gas dryer timer issues (Dryer Repair)
by Paul DeMers 9/4/2009 4:53:33 PM(UTC)
