vincent1723
#1 Posted : Wednesday, March 6, 2013 5:40:27 PM(UTC)
vincent1723
Hi my microwave recently made a loud pop and then quit heating everything else seemed fine ,took to a repair shop for 50 bucks they told me I needed a new magnetron and diode for a price of 300 more I decided to repair myself ordered the parts and replaced them, seemed pretty simple.but when i plugged it in to give it a test it came on for about a second then everything shut down no power period.Seems like it has to be a fuse but what would cause this . any help would be grateful.I am determined Thanks Vincehttp://forum.appliancepa...images/smilies/smile.gif
#2 Posted : Thursday, March 7, 2013 2:10:23 PM(UTC)
Hello,
Possible the high voltage capacitor (#2 at the diagram) is shorted out. Open the control panel to access the capacitor and the fuse.
Discharge the capacitor and check it for continuity.
- The high voltage capacitor Part number: 5303319549
- The fuse kit (included the monitor switch) Part number: 5303319559
vincent1723
#3 Posted : Friday, March 8, 2013 9:40:05 AM(UTC)
vincent1723
Thanks Gene if capacitor was bad would that cause the no heating and display to go out.when i took my microwave in to have it checked everything worked just no heat then when i replaced mag and diode it instantly shut it all down wondering if the appliance store give me wrong advice i checked the old mag and diode by the directions and both checked fine.would capacitor short the fuses
#4 Posted : Friday, March 8, 2013 1:52:52 PM(UTC)
If the capacitor is open then the microwave would not heat.
If the capacitor is shorted then it will blow the fuse.
Guest (5)
