jeffmreyn
#1 Posted : Sunday, March 3, 2013 7:28:21 AM(UTC)
jeffmreyn
Had some kind of problem with electric oven; breaker tripped; looked oven over & found what appeared to be shorted oven light - weird - burn marks; removed oven light receptacle and taped off connecters; turned on power to oven; no error codes; top elements work; warmer element works; have 120V at L1; control panel responds to request to bake or broil; with controls calling for bake or broil have 120V at L2 & bake & broil terminals at EOC; but do not get 240V when testing L2 to bake or L2 to broil; checked continuity of temperature sensor (1070 ohms) and elements (15 ohms); they are okay. Suggestions?
#2 Posted : Monday, March 4, 2013 2:10:36 AM(UTC)
Parts for Kenmore Range 79094222403 - AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/p...pringfield/316417748.pdf
Sounds like the voltage spike caused by the oven light problem blew the control board. L2 is not being switched in.
Click on the picture for more info about the part.
Part number: AP4587739
You may also need the overlay. Often they do not come off the old timer undamaged. If it is stubborn try heating it up with a hair dryer to loosen the glue.
You can see them if you look at the parts link and then look at Touch Pad in the Part Type section.
jeffmreyn
#3 Posted : Wednesday, March 6, 2013 5:14:19 PM(UTC)
jeffmreyn
Thanks for your help. Installed control panel and new oven light. Wife happy.
#4 Posted : Thursday, March 7, 2013 1:12:14 AM(UTC)
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause
