Hi! I'm completely ignorant about appliance repair and am hoping and praying someone can point me to (or invent) a schematic that shows/explains the VERY detailed assembly of the chopper for my dishwasher. When I took it out to clean the disgusting gunk out of it, I got a little too enthusiastic I guess, and it fell apart. I think I've got it put together properly, but I don't want to put the whole thing back together and discover it doesn't work anymore. Here's what I've got figured out maybe: -First there's the plastic shaft with the spring -On top of that is a metal washer -Then the grinder/filter disk thing. One side seems to be rougher so I've got that side facing 'out' toward the blades -Then another metal washer - Then the blades with the flange-y things facing 'out' and stuck under some lip things on the plastic shaft Oh yeah - my other problem is I can't get the metal cap to stay on the shaft. I read how to fix that here How To Repair Dishwashers/KitchenAid Repair/Chopper Replacement - Wikibooks, open books for an open world but I'm not sure specifically how to accomplish the melting part so I could use some advice about that as well if possible. So that's my problem. MANY thanks in advance to anyone who can help me figure this out! ~Claire
Hi Claire, If the old chopper fell apart then the solution is to buy and install the new part. - The chopper Part number: W10083957
Actually, I fixed it. Thanks for the advice though.
