2 Pages12>
erintu81
#1 Posted : Friday, March 1, 2013 10:42:45 AM(UTC)
erintu81
Frigidaire FGHS2644KF. Fridge just died. It started with a error code of 5YCF and the fridge side of the light was off but the cooling was still working. That night the fridge kept running on and off, on and off, with beeping following after. Next morning freezer light was off and no more cooling. Fridge is dead. What could be the problem?
#2 Posted : Friday, March 1, 2013 5:01:03 PM(UTC)
Sounds like the problem is a bad power control board.
If you need the correct part number for the control board, post the end of the model number.
erintu81
#3 Posted : Friday, March 1, 2013 5:11:21 PM(UTC)
erintu81
Thank you. FGHS2644KF0
I had a feeling that was the problem. Would the part # be 241973702 ?
#4 Posted: : Friday, March 1, 2013 5:23:24 PM(UTC)
The correct power control board Part number: 5303918514
The part number you posted is for the dispenser control board.
Here are the breakdown diagrams and Parts for Frigidaire FGHS2644KF0 Refrigerator - AppliancePartsPros.com
erintu81
#5 Posted : Friday, March 1, 2013 5:33:29 PM(UTC)
erintu81
Thank you very much.
erintu81
#6 Posted : Friday, March 1, 2013 5:40:22 PM(UTC)
erintu81
Where would this item be located on the refridgerator? I was thinking it was the backing of the ice dispenser when removed looks like a green board but I guess that was the dispenser control board.
#7 Posted : Friday, March 1, 2013 6:22:43 PM(UTC)
It is shown as #50 at the diagram.
erintu81
#8 Posted : Friday, March 1, 2013 6:36:28 PM(UTC)
erintu81
I don't understand the diagram. Is it behind the dispenser or is it inside the refridgerator?
#9 Posted : Monday, March 4, 2013 5:21:58 PM(UTC)
It has nothing to do with the dispenser. This board is located under the refrigerator behind the kick plate.
erintu81
#10 Posted : Tuesday, March 5, 2013 9:45:38 AM(UTC)
erintu81
Thank you. Husband found it. We had a hard time figuring out the diagram. Parts are ordered, hopefully this fixes the problem.
2 Pages12>
