Forum Rank:: Member
Frigidaire FGHS2644KF. Fridge just died. It started with a error code of 5YCF and the fridge side of the light was off but the cooling was still working. That night the fridge kept running on and off, on and off, with beeping following after. Next morning freezer light was off and no more cooling. Fridge is dead. What could be the problem?
Sounds like the problem is a bad power control board.
If you need the correct part number for the control board, post the end of the model number.
Forum Rank:: Member
Gene. Thank you. FGHS2644KF0 I had a feeling that was the problem. Would the part # be 241973702 ?
Forum Rank:: Member
Originally Posted by: Gene Thank you very much.
Forum Rank:: Member
Originally Posted by: Gene Where would this item be located on the refridgerator? I was thinking it was the backing of the ice dispenser when removed looks like a green board but I guess that was the dispenser control board.
It is shown as #50 at the diagram. Gene.
Forum Rank:: Member
Originally Posted by: Gene It is shown as #50 at the diagram. Gene. I don't understand the diagram. Is it behind the dispenser or is it inside the refridgerator?
It has nothing to do with the dispenser. This board is located under the refrigerator behind the kick plate.
Forum Rank:: Member
Originally Posted by: Gene It has nothing to do with the dispenser. This board is located under the refrigerator behind the kick plate.
Gene. Thank you. Husband found it. We had a hard time figuring out the diagram. Parts are ordered, hopefully this fixes the problem.
