billsooner
#1 Posted : Monday, March 4, 2013 4:14:54 PM(UTC)
billsooner
Found my clothes sopping wet and a burning smell at end of washing cycle.
Checked and found that it is still agitating, draining, and spinning (only when there is NO CLOTHING).
When I put it on spin cycle with clothes, you can hear the motor? trying to run, but nothing is happening (I am assuming where the burning smell is coming from). When I take the clothes out, and try spinning, it seems to get going fine.
I checked underneath and did not see any "rubber shavings" as I have seen on other a "coupling" problem.
PLEASE HELP! I am a teacher and am barely surviving month to month, I can't afford buying a new one or costly repairs.
Simon / APP Team
#2 Posted : Monday, March 4, 2013 4:51:32 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check two things first.
Remove the agitator and check if the drive block still has the grooves and engaging the spin tube.
The drive block Part number: 389140
Part number: 389140
Next, if the drive block is good - replace the clutch Part number: 285785
Part number: 285785
Use the video clip for the instructions.
Here are the breakdown diagrams and Agitator, Basket and Tub parts for Whirlpool LSB6500PW0 - AppliancePartsPros.com
Post the results.
Simon.
