gmpfeffer
#1 Posted : Sunday, February 24, 2013 1:42:19 PM(UTC)
gmpfeffer
My kitchenaid icemaker is not working. Model number is KSRP25FNSS00. The water dispenser is working. I cannot tell if the water inlet valve is operating properly. Should there be water dripping from the water tube above the icemaker into the icemaker when the icemaker is on and the flapper door closed? There wasn't any when I watched it. When the icemaker is on and the flapper door closed, the LED light stays lit continuosly When I pulled the automatic icemaker out, there was a small plastic piece broken off from the center of the white gear (a retainer?) on the motor assembly. Maybe the gear was inoperable having only about half the retainer there? Nothing seemed loose on the gear.
Thanks for any help you can give me.
#2 Posted : Monday, February 25, 2013 12:39:13 PM(UTC)
Originally Posted by: gmpfeffer Go to Quoted Post
...a small plastic piece broken off from the center of the white gear...
Hello,
It points to a bad ice maker.
- The ice maker Part number: 2198597
Kitchenaid Icemaker not working (Refrigerator & Freezer Repair)
by Stekelenburg 12/12/2012 9:55:44 AM(UTC)
kitchenaid icemaker not working (Refrigerator & Freezer Repair)
by Kewoldt 12/3/2011 7:13:17 PM(UTC)
by Dan54 2/28/2011 11:39:01 PM(UTC)
KitchenAid icemaker not working (Refrigerator & Freezer Repair)
by Anilkumar15 12/31/2010 5:44:41 PM(UTC)
Kitchenaid icemaker not working (Refrigerator & Freezer Repair)
by jjjacek 6/5/2010 4:45:22 AM(UTC)
Kitchenaid Icemaker Not Working (Refrigerator & Freezer Repair)
by Doug_dallas 6/8/2009 2:00:59 PM(UTC)
by jayconnor 12/30/2007 7:15:37 AM(UTC)
