[FONT=Arial","sans-serif]The dishwasher runs fine. After we unload it and then reload it, it won't start. When we hit the start button it just beeps 15 times and nothing happens. Then I go to the circuit breaker and shut down the power to the dishwasher for 10 seconds then turn the circuit breaker back on. After that the dishwasher works fine for one cycle. Basically I have to hit the circuit breaker each time to run it. Any advice would be appreciated.[/FONT]
[FONT=Arial","sans-serif]Thanks,[/FONT] [FONT=Arial","sans-serif]Tom[/FONT]
Groups: APP Team
Hi.
It's not an ordinary problem. Try to replace the control panel first, then the control board. Get both parts and return the one you don't need.The APP will take it back even if you installed it. Provide the complete model number of the unit.Missing the last digit.
Simon.
FYI. The problem was a bad door latch sensor.
