I have a new timer for the dryer but do not know how to remove the dial. The new part is threaded on the dial shaft end, is this true on the original timer? Does it just pull off? I am afraid to damage the dial.
Groups: APP Team
Hi.
Pry out the cap in the middle of the timer knob.
Unscrew the nut and remove the knob.
Pull out the dial skirt.
Good luck.
Simon.
Thanks, it was invisible to me!
Groups: APP Team
Dial removal
(Washer Repair)
by mikehw
7/2/2010 8:08:10 AM(UTC)
Timer dial removal
(Washer Repair)
by Tom C
8/12/2008 10:48:55 AM(UTC)
