Glen Barclay
#1 Posted : Tuesday, February 19, 2013 4:46:47 PM(UTC)
Glen Barclay
I have posted this before but due to my advanced age can't recall some of the info. The refrigerator drain freezes up about 3 times a year. I do the turkey baster and blow dryer routine which lasts about 4 months. What I am searching for is a lasting "cure" to the curse. At one point it was suggested to wrap a bare copper wire around the defroster and direct it into the drain. I did that and when it froze up the last time I found that the frozen water had pushed the wire out of the hole. Alas we once again have water seeping into the fresh section. Somewhere I saw a part that could be installed for about $25.00 to cure the problem but I cannot remember where I saw it.
#2 Posted : Wednesday, February 20, 2013 2:17:37 AM(UTC)
I believe this is what you are referring to.
Click on the picture for more info about the part.
Part number: 819043
Part number: 819043
A couple other things to check.do are.
1. Make sure that the part the water takes to the drain line is clean, no residue etc.
2. Sometimes a coating of buffed up wax will help the water drain faster.
Glen Barclay
#3 Posted : Thursday, February 21, 2013 12:08:22 PM(UTC)
Glen Barclay
Part number: 819043
Part number: 819043
Thanks for the reply and information. It looks like what I saw before and hopefully will resolve the problem. Do I need to replace the defrost assembly as well?
Glen Barclay
#4 Posted : Thursday, February 21, 2013 12:27:50 PM(UTC)
Glen Barclay
Thanks for the information. Do I need to replace the defrost heater as well as installing the device that will extend down the drain tube?
#5 Posted : Friday, February 22, 2013 12:39:52 AM(UTC)
You are missing the first 3 numbers at the start of the given model number so I cannot look up what type of defrost heater this unit uses.
Glen Barclay
#6 Posted : Monday, February 25, 2013 2:30:08 PM(UTC)
Glen Barclay
the model # starts with 106. So it's 106.71194100.
As inquired before, should I replace the defrost heater at the same time as part # 819403?
#7 Posted : Tuesday, February 26, 2013 1:47:52 AM(UTC)
You did not mention any problems with the evaporator coils not defrosting OK so the defrost heater should be OK.
Glen Barclay
#8 Posted : Tuesday, February 26, 2013 3:11:39 PM(UTC)
Glen Barclay
Thanks. I was confused as the original info I got had pictures of the bracket as well as the defrost heater (u shaped).
