jimconyers@centex.net
#1 Posted : Tuesday, February 19, 2013 12:53:53 PM(UTC)
Water flows from a small supply tube into the reservoir then fills the ice bin then overflows into floor. Turning unit off or unplugging unit did not stop water flow. Had to turn off supply at wall. Does this sound like the water valve OR the solenoid?
Joe / APP Team
#2 Posted : Tuesday, February 19, 2013 1:13:53 PM(UTC)
Joe / APP Team
Jim, Yes, it does sound like a mechanical failure, inside the water valve
Part number: AP4362516
That's where you're going to want to start.
Thanks,
Ice machine leaks when dispensing water (Refrigerator & Freezer Repair)
by raterus 4/22/2009 4:06:24 AM(UTC)
