bmase
#1 Posted : Tuesday, February 19, 2013 9:23:07 AM(UTC)
bmase
Dishwasher has worked flawlessly for 2 years, all of a sudden it does not run, when control panel buttons depressed the lights illuminate on all cycles but it does not start to fill, and times out after 1 minute and shuts down, I have removed the front control panel and checked the door micro switch and its checks out fine with an ohmeter. what is my next step please?:confused:
Simon / APP Team
#2 Posted : Tuesday, February 19, 2013 12:01:48 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
To determine if this is the control panel versus the control board check the J1 plug pins 10-6. With Start/Cancel pressed according to the manual you should read 10Komh. If you have correct reading - replace the control board, if not - control panel.
Here are the breakdown diagrams and 02-Control Panel Parts parts for Maytag MDB7609AWS2 - AppliancePartsPros.com
Keep in mind that you can return any parts you don't use back to APP.
Post the results.
Simon.
bmase
#3 Posted : Tuesday, February 19, 2013 12:39:19 PM(UTC)
bmase
Simon
Thank you for your reply, I will check this out after work tonite, am an electrician so understand your directions, definitely not a cheap fix either way by the sounds of it.
Brian
Simon / APP Team
#4 Posted : Tuesday, February 19, 2013 1:29:30 PM(UTC)
Simon / APP Team
Groups: APP Team
Post the results, please.
Simon.
bmase
#5 Posted : Tuesday, February 19, 2013 3:22:41 PM(UTC)
bmase
will do, when I am done
bmase
#6 Posted : Wednesday, February 20, 2013 7:49:08 AM(UTC)
bmase
Hello Simon
I tested the resistance at pins 10 and 6 and got 1.6 megs, however now I have no light on the front panel, not sure if some static may have spiked the board, do you think the control card may be the culprit?
Simon / APP Team
#7 Posted : Wednesday, February 20, 2013 1:27:27 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Sounds like the control panel is done.Replace it.
Post the results.
Simon.
WeAreNotAlone
#8 Posted : Monday, September 12, 2016 7:02:30 PM(UTC)
WeAreNotAlone
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Post the results.
Simon.
Originally Posted by: bmase Go to Quoted Post
Hello Simon
Hi.
Post the results.
Simon.
Bmase,
Suggested fix was the control panel, and you said you'd post back what fixed the MayTag MDB7609AWS2 dishwasher once you fixed it.
What was the FIX?
Was it the control board, the panel... OR something else?
