My freezer coils are not completely frozen. If there are 7 coils, two of them have frost. I have vacuumed around the compressor area and cleaned out vents. Not sure what else to check. Thanks
Here are your parts Parts for Whirlpool ER8YHMXSL01 Refrigerator - AppliancePartsPros.comI am assuming that the compressor runs all the time except when it is in defrost. Sounds like you are low on freon. Be sure that the compressor has run for several hours before checking your coils. If you check them shortly after or during a defrost cycle you could come to the wrong conclusion. Below is a good link, check out the example pictures about half way down the page. http://www.applianceaid.com/refrigerator-not-cold-enough.phpIf it is low on freon, it will be an expensive repair as you need a pro. Also there is no use adding freon until the leak is found and fixed. Often it makes more sense to put those dollars towards a new unit. I would check the warranty as many units have a longer sealed system warranty. |
THIS FORUM IS DEAD!!!!!!! |
