rich denison
#1 Posted : Monday, February 18, 2013 9:10:54 AM(UTC)
rich denison
[MODEL][/MODEL]richdenison@hotmail.comAfter reviewing responses on your forum regarding ovens that will not get hot, I replaced the ignitor. Unfortunately the new ignitor only glows orange and the oven will not light. The broiler and stove top work.
Joe / APP Team
#2 Posted : Monday, February 18, 2013 1:50:05 PM(UTC)
Joe / APP Team
Rich, sounds like you installed a weak or faulty ignitor.
Part number: AP3008600
or there is a loose connection. You'll need a clamp on ammeter or multi meter to test the circuit.
With a clamp on meter, place the clamp around one of the igniter wires and select a bake temp. Within 60 to 90 seconds, the igniter should draw 3.2 to 3.6 amps on the meter and glow "white" hot.
With a multi meter set to read VAC. select a bake temp. within 60 to 90 seconds, the igniter should produce a voltage reading of 3.2 to 3.6 VAC across the safety valve terminals, with the wires attached and glow "white" hot.
Low amperage draw, low voltage reading, or an orange to red glow indicate a weak or damaged ignitor, or loose wire connection.
Oven will not get hot enough (Oven Repair (including Ranges and Cooktops))
by Racup 10/18/2014 6:07:00 PM(UTC)
Hot Point/GE oven will not get hot (Oven Repair (including Ranges and Cooktops))
by jssncaz 10/5/2010 9:44:02 AM(UTC)
GE Range Oven will not get hot (Oven Repair (including Ranges and Cooktops))
by jlyrepair 9/22/2010 11:15:01 AM(UTC)
by skypilot01 6/29/2009 5:31:53 PM(UTC)
Whirlpool Oven will not get hot in bake but will broil (Oven Repair (including Ranges and Cooktops))
by 7faces 12/19/2008 1:31:48 PM(UTC)
