eosada
#1 Posted : Sunday, February 17, 2013 6:10:32 AM(UTC)
eosada
The washer does everything but agitate. Is it a coupler or a transmission problem? I can't figure out how to remove the agitator. Please help!
fairbank56
#2 Posted : Sunday, February 17, 2013 3:08:22 PM(UTC)
fairbank56
Groups: Expert
To remove the agitator, place a strap under it near the center and yank upwards to pop it off. If you can rotate the agitator coupler easily by hand, the splines are probably stripped out. Remove the bolt and coupler to inspect inside it for stripped splines.
Eric
GE Washer Not Agitating or Spinning (Washer Repair)
by Gator84 8/17/2015 4:34:56 PM(UTC)
by KerriH 7/19/2013 9:06:57 AM(UTC)
GE washer not agitating (Washer Repair)
by rfm1 5/21/2013 3:54:45 AM(UTC)
GE washer not agitating properly (Washer Repair)
by aav 6/23/2012 8:30:14 AM(UTC)
GE Washer Not Agitating (Washer Repair)
by skeeskinner 12/20/2011 5:15:24 PM(UTC)
by Ellen Clark 8/15/2011 8:36:42 PM(UTC)
GE Washer Not Agitating, Transmission Fine (Washer Repair)
by silvz72 6/9/2010 9:09:12 AM(UTC)
by penninger7142 5/7/2009 5:07:20 PM(UTC)
