hathawayrepair
#1 Posted : Saturday, February 16, 2013 7:12:35 PM(UTC)
hathawayrepair
Maytag Centennial washer leaking oil. Is there a service manual for this model?
sidfink43
#2 Posted : Monday, February 18, 2013 4:05:17 PM(UTC)
sidfink43
Hopefully all the problem here is a bad seal on the transmission housing. Here is a schematic of your parts
Part number: AP4410608
I cannot link you to a service manual but if you go to the video section on this site you can find videos that will show you how to tear down a Whirlpool direct drive washer, which is what this is.
You can try replacing the seal and filling it back with oil, but given the cost of a new transmission I would not go that route and instead would replace the machine with a new one. It's not that much more cost and you will have a new machine with factory warranty.
jacobwilson8
#3 Posted : Monday, June 17, 2013 9:46:14 PM(UTC)
jacobwilson8
Where did you purchase the washer? And is it a private residence or commercial? Most washers have warranties, so if it's not an easy fix, see if you can have it serviced or replaced. I know Mac-Gray runs the washers and dryers in my apartment building and we never have issues like that. Lastly, a Google search is always helpful for issues such as this one. Best of luck!
fairbank56
#4 Posted : Tuesday, June 18, 2013 4:56:03 AM(UTC)
fairbank56
Groups: Expert
Your machine is not a Whirlpool direct drive design, it is the newer Whirlpool belt drive design. The transmission is probably leaking and it is not serviceable, must be replaced.
Whirlpool W10473143 Gearcase - AppliancePartsPros.com
Here is the parts breakdown for your model.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10401558.pdf
Eric
Guest (5)
