steese60
#1 Posted : 12 years ago
steese60
Washer Will Fill With Water But Will Not Agitate Or Spin, Just Makes Humming Sound..then After 1 Minute It Will Drain..i Replaced The Agitator Coupling Kit..but Didn't Fix It...what Next?
fairbank56
#2 Posted : 12 years ago
fairbank56
Groups: Expert
Is the timer dial moving while it's filling?
Eric
steese60
#3 Posted : 12 years ago
steese60
Eric
yes it does move
fairbank56
#4 Posted : 12 years ago
fairbank56
Groups: Expert
It's not supposed to move while filling. You may have a bad timer but I would check the inverter for error codes as well. Remove the front panel and check the flashing LED on the inverter board on top of the motor. With the washer in standby, it should be flashing on/off every second and with the washer running it should be on/off every 1/2 second. If there is an error code, it will flash the error number such as 4 quick flashes and then off within a 6 second period is error code 4.
Eric
GE washer grinding noise (Washer Repair)
by gefixin 10 months ago
GE Washer Topload model I have a GE top load washer GTW750CPL0DG. It fills and it is running but whe (Washer Repair)
by MimiReel about a year ago
GE washer GTW750CPL0DG (Washer Repair)
by Guest about a year ago
GE Washer with bad transmission? (Washer Repair)
by fljlee3 about a year ago
GE washer and dryer lost face clothes (Washer Repair)
by chris24681012 about a year ago
GE washer drain problem (Washer Repair)
by gurka75 about a year ago
GE washer model GTWN4250D0WS fill water but will not agitate or spin during wash cycle (Washer Repair)
by Dweynand 2 years ago
GE Washer model GFAN1000L2WW. Stucked during the washing process with no agitation. (Washer Repair)
by Guest 2 years ago
GE Washer GLWN5550D0WW trying to test if the shifter disengage from the wash basket (Washer Repair)
by steveh1776 2 years ago
GE washer will spin but will not agitate on the wash cycle (Washer Repair)
by Jodibrewer2002@yahoo.com 2 years ago
GE WASHER MAKES GOD AWFUL SOUND AFTER FILLING WITH WATER (Washer Repair)
GE Washer GTW335ASN1WW (Washer Repair)
by jmulc82189 2 years ago
GE Washer Ending Cycle after abt 3-5 mins (Washer Repair)
by FelixSS 2 years ago
GE washer wbse4220aoww (Washer Repair)
GE washer- washes clothes, spins, drains then fills w water again (Washer Repair)
by Skep19 2 years ago
