ajdixon
#1 Posted : Saturday, February 9, 2013 9:28:01 AM(UTC)
ajdixon
stabilizers were bad replaced them, do not hear timer moving or clicking, will fill with water yet will not spin! removed cover and motor and drum spin free and easy. where to start?
sidfink43
#2 Posted : Monday, February 11, 2013 3:40:34 PM(UTC)
sidfink43
There are two likely sources of your problem on this model, the door lock assembly and the speed/motor control board.
First check to make sure all the connections are solid. You may have loosened something while making the repair.
If they check out try replacing the door lock assembly and then try to check the speed control board using procedures from the tech notes that should have been inside the lower service panel.
Sears front loader wont spin out (Washer Repair)
by thebigguy1@fastmail.fm 9/3/2011 11:14:14 AM(UTC)
kenmore front loader wont spin or agitate (Washer Repair)
by rrpackageplus 3/24/2011 11:44:43 AM(UTC)
Front loader wont spin (Washer Repair)
by robnrobn2000 1/2/2010 2:01:44 PM(UTC)
Kenmore Front Loader wont spin in any cycle (Washer Repair)
by gerac 7/20/2009 6:14:22 PM(UTC)
Kenmore Front Loader wont spin (Washer Repair)
by corrales 5/14/2009 8:34:40 AM(UTC)
front loader wont spin (Washer Repair)
by n1ktc 11/5/2008 6:55:06 AM(UTC)
