Ziggi
#1 Posted : Friday, February 8, 2013 11:15:49 AM(UTC)
Ziggi
I have just hooked up the oven to propane and the flame is Yellow on High and seems to be putting out too much propane. I adjusted the regulator so that the LP is facing out for Propane right? I changed it back to where the N is facing out (for Natural gas?) and it is better, but it is still making my pots black and the flame is Yellow on High. Is this a regulator problem, or do you have another idea?
#2 Posted : Friday, February 8, 2013 4:33:45 PM(UTC)
Hello,
In order to convert the range for LP gas you must use the special conversion kit which comes with the installation instructions. All of the orifices must be replaced.
- The conversion kit Part number: 74009269
