I have just hooked up the oven to propane and the flame is Yellow on High and seems to be putting out too much propane. I adjusted the regulator so that the LP is facing out for Propane right? I changed it back to where the N is facing out (for Natural gas?) and it is better, but it is still making my pots black and the flame is Yellow on High. Is this a regulator problem, or do you have another idea?
Hello, In order to convert the range for LP gas you must use the special conversion kit which comes with the installation instructions. All of the orifices must be replaced. - The conversion kit Part number: 74009269
