Obuasi
#1 Posted : Friday, February 8, 2013 4:30:18 AM(UTC)
Obuasi
Hot water does not dispense into the washer on any of the water temp settings.
If I switch the water lines, hot water will fill up via the cold water setting.
I already checked the hoses, water supply, and power.
Note: I replaced the Water Inlet Valve yesterday with a brand new unit and the problem remains.
All other functions on the washer are okay.
Any suggestions are appreciated.
Thank you.
Chris
fairbank56
#2 Posted : Friday, February 8, 2013 5:09:17 AM(UTC)
fairbank56
Groups: Expert
Bad water temp selector switch. Could also be a bad connection/wire between water temp switch and timer/water inlet valves. Inspect those first and check with meter if you have one.
Eric
Obuasi
#3 Posted : Friday, February 8, 2013 5:15:44 AM(UTC)
Obuasi
I appreciate the suggestion - I should have first checked the connection/wire between water temp switch and timer/water inlet valves.
It just may be the switch. I went for the cheaper part replacement first.
Thanks again.
Guest (5)
No hot water in washer (Washer Repair)
by gladys09 2/21/2010 7:15:43 AM(UTC)
