CoriG
#1 Posted : Saturday, February 2, 2013 11:31:21 AM(UTC)
CoriG
Our older model wall oven has stopped working after using the self cleaning program. The lights and digital panel still work but the heat and broiling functions have stopped. Thanks, hope you can help.
#2 Posted : Sunday, February 3, 2013 2:52:46 AM(UTC)
Parts for Whirlpool YRBS275PDQ6 Wall Oven - AppliancePartsPros.com
Odds are tat the thermal overload (item 37 in The Oven Parts section) has blown.
I would check the power first just to be sure you have not lost half the line. The control panel/light uses half the line (120 volts) but the elements require the full 240.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If the power is OK remove power from the unit and check the thermal overload.
It should be 0 ohms.
File Attachment(s):
YRBS275.pdf (575kb) downloaded 5 time(s).
frigidaire wall oven 6564063 (Oven Repair (including Ranges and Cooktops))
by Guest 7/2/2024 12:40:53 PM(UTC)
GE Wall Oven Model PT7800SH9SS (Oven Repair (including Ranges and Cooktops))
by 68catcar 5/21/2024 6:06:03 PM(UTC)
thermador double wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 4/8/2024 11:57:14 PM(UTC)
1950s ge wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 3/8/2024 6:02:49 PM(UTC)
Viking Wall Oven VGSO 166 Temperature Probe (Oven Repair (including Ranges and Cooktops))
by RRR5678 2/20/2024 4:15:01 PM(UTC)
Vintage Wall Oven SIZES (General Talk)
by sabfre 12/21/2023 8:52:31 AM(UTC)
GE Monogram Electric Wall Oven Model No. Z EK938SM1SS (Oven Repair (including Ranges and Cooktops))
by Govtman 11/14/2023 7:24:46 PM(UTC)
Kenmoore wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 6/23/2023 1:46:47 PM(UTC)
whirlpool double wall oven BROIL on BAKE (Oven Repair (including Ranges and Cooktops))
by Guest 6/4/2023 8:04:00 PM(UTC)
Thermador wall oven temp sensor (Oven Repair (including Ranges and Cooktops))
by dxg2 6/4/2023 11:36:40 AM(UTC)
Gaffers and Sattler wall oven 1970-1980 models (Oven Repair (including Ranges and Cooktops))
by Guest 3/19/2023 2:45:52 PM(UTC)
Determining voltage for 1960s GE-J-720 wall oven install (Oven Repair (including Ranges and Cooktops))
by Austo1989 2/22/2023 4:33:49 PM(UTC)
Jenn air double wall oven control panel problems (Oven Repair (including Ranges and Cooktops))
by Guest 2/2/2023 3:45:53 AM(UTC)
Old GE Double Wall Oven - Top isn't working (Oven Repair (including Ranges and Cooktops))
by Doubletheoven 11/25/2022 5:19:46 AM(UTC)
Maytag wall oven door won't unlock (Oven Repair (including Ranges and Cooktops))
by Guest 9/13/2022 10:44:59 AM(UTC)
