jj3900
#1 Posted : Thursday, January 31, 2013 12:47:57 PM(UTC)
jj3900
Hello, dryer was stopping before cycle complete, think may have been caused by too many back to back loads or heavy loads. Recently dryer is not heating up. We have checked the following (heating element replaced, thermostat, hi-thermostat, cycling thermostat, thermal fuse, vent clear, breaker box) all seems to be good, so not sure what the issue is or what we may have missed. Any help is appreciated. Thx in advance!
#2 Posted : Saturday, February 2, 2013 3:31:24 AM(UTC)
Parts for Maytag NED4800VQ1 Dryer - AppliancePartsPros.com
See the attachment for the tech sheet
First I would check the power. The motor and timer run off half the line (120 volts) but the heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
File Attachment(s):
NED4800.pdf (587kb) downloaded 2 time(s).
