AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
Keypad works and light comes on: turntable doesn't work and no hum or blower sound
The light comes on and the keypad works fine. When you press start,it starts counting down and the light stays on but the turntable does not spin and nothing else happens. It is silent. No blower or humming. I tried auto settings like "popcorn" and had the same result. I flipped the breaker off to try to reset it and nothing changed. Does anyone have any ideas?
Originally Posted by: Palmer41420  The light comes on and the keypad works fine. When you press start,it starts counting down and the light stays on but the turntable does not spin and nothing else happens. It is silent. No blower or humming. I tried auto settings like "popcorn" and had the same result. I flipped the breaker off to try to reset it and nothing changed. Does anyone have any ideas? Check your door switches for continuity with the power disconnected and at least one terminal removed from the switch.
Microwave Repair
