lclark
#1 Posted : Wednesday, January 30, 2013 4:32:31 AM(UTC)
lclark
I have a GE dishwasher that would not do anything,so I replaced the control board.When I put power to it the clean light blinked on and off and beeps also.I would try to reset it again and the same thing happens.Any helpwould be greatly appreciated.
#2 Posted : Wednesday, January 30, 2013 3:17:27 PM(UTC)
Hello,
After you replaced the control board the dishwasher should go through the calibration automatically. The dishwasher will enter into the calibration mode when the unit is first powered on. The door must be closed and latched. You have to wait approximately 6 minutes for the second fill before canceling the cycle by pressing the start reset pad.
Did you do it?
lclark
#3 Posted : Thursday, January 31, 2013 3:53:34 AM(UTC)
lclark
I did not wait the 6 min.When i powered up and the clean light blinked on and off and beeped until I pressed a button the beeping stopped but the clean light still blinked on and off.I did this several times.
#4 Posted : Thursday, January 31, 2013 3:03:53 PM(UTC)
Possible it did not finish the calibration. Try to do it again from the scratch.
lclark
#5 Posted : Friday, February 1, 2013 8:58:56 AM(UTC)
lclark
I tried it from scratch,does the same thing.Clean light flashes and beeps.I waited 10 min.Can you tell me how you put into service mode?
#6 Posted : Friday, February 1, 2013 11:47:43 AM(UTC)
Sure. The procedure described in the attached mini-manual.
File Attachment(s):
31-30477 (1) - GLD4500N10WW.pdf (583kb) downloaded 102 time(s).
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
GE Dishwasher GDF620HMJ2ES (Dishwasher Repair)
by lou@officenerd.com 1/14/2024 3:32:20 PM(UTC)
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
GE Dishwasher Model GDT655SSJ2SS (Dishwasher Repair)
by Dan Jones 11/16/2023 11:33:43 AM(UTC)
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 6/7/2023 2:40:51 PM(UTC)
GE dishwasher GDT580SSF5SS water doesn't get hot and dishes are not drying (Dishwasher Repair)
by jmbuffy 5/15/2023 4:45:57 PM(UTC)
GE Dishwasher Loads water but never agitates to clean dishes (Dishwasher Repair)
by Guest 4/19/2023 6:38:21 AM(UTC)
GE Dishwasher, Model: GDF530PGM0WW (Dishwasher Repair)
by Guest 4/12/2023 12:06:40 PM(UTC)
GE Dishwasher GSD900D-02 Door Gasket Gap (Dishwasher Repair)
by DJW000 2/5/2023 10:05:34 AM(UTC)
GE Dishwasher dead UI board (Dishwasher Repair)
by Guest 1/26/2023 9:44:03 PM(UTC)
GE dishwasher - general query about a ball at the back in the tube (Dishwasher Repair)
by delboy1881 7/27/2022 7:49:15 AM(UTC)
GE Dishwasher beeps every 10 seconds (Dishwasher Repair)
by bethH 7/12/2022 3:03:53 AM(UTC)
Ge dishwasher seal replacement (Dishwasher Repair)
by Guest 4/21/2022 5:34:16 AM(UTC)
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 4/19/2022 7:32:28 AM(UTC)
GE dishwasher not filling and other problems (Dishwasher Repair)
by Guest 4/14/2022 3:40:35 PM(UTC)
