3 Pages<123
fairbank56
#21 Posted : Wednesday, January 30, 2013 12:19:40 PM(UTC)
fairbank56
Groups: Expert
Well, I can only suggest that something didn't go back together correctly. Does it actually agitate and spin or is the motor just humming? Any time you remove the gearcase, before re-installing it, you must make sure the basket drive is fully seated because pulling the gearcase out can cause the basket drive to come out a little bit. You must grab the brake cam driver, turn it CCW while pushing the drive to make sure the drive and brakes are fully seated into the brake hub. Then when installing the gearcase, make sure the spring on the clutch band is exactly opposite the spring up in the brake hub. This ensures that the clutch spring doesn't get jammed up against the tab of the brake cam driver. Make sure the gearcase is fully up against the mounting tubes before replacing the bolts.
Eric
tresor
#22 Posted : Wednesday, January 30, 2013 5:00:45 PM(UTC)
tresor
hi Eric,
Once again many many thanks for all your insightful info. We finally got it to work properly! We replaced the clutch and then after moving the machine back and forth to it's cabinet, the loud buzzing noise stopped. It doesn't slow spin any more nor is there a burning smell. The clutch seemed to have been the culprit for all these initial problems.
I am sooo grateful, thank you all for your advise and concern.
maria
Slow spin - clicking drum (Washer Repair)
by Machine_Slo 1/6/2020 9:18:40 PM(UTC)
Noise during the fast spin cycle, but not slow spin cycle (Washer Repair)
by onthego4858 6/17/2017 10:18:24 AM(UTC)
Slow spin cycle (Garbage Disposer Repair)
by Cbus 4/26/2016 11:35:11 AM(UTC)
Whirlpool top load very very slow spin (Washer Repair)
by Docken 10/22/2014 5:31:26 PM(UTC)
Intermittent stuck on slow spin (Washer Repair)
by pmhstar 4/28/2014 10:58:36 AM(UTC)
No agitation and clicking during slow spin (Washer Repair)
by Whirlpool ray 12/6/2013 8:54:59 PM(UTC)
Whirlpool top loader slow spin cycle (Washer Repair)
by Re Vera 6/24/2013 12:34:34 PM(UTC)
Intermittent Slow Spin (Washer Repair)
by imageshift 4/2/2013 8:49:27 AM(UTC)
by twg2 4/26/2012 7:40:43 AM(UTC)
No spin or slow spin (Washer Repair)
by Morrisp 10/17/2011 1:02:27 PM(UTC)
slow spin and noisey in rinse cycle (Washer Repair)
by indoorairpro 9/25/2011 8:34:40 AM(UTC)
Leak & Slow Spin (Washer Repair)
by 4evrmoor 4/20/2011 9:14:26 AM(UTC)
Maytag Performa washer, slow spin speed (Washer Repair)
by hank b 4/18/2011 7:26:54 AM(UTC)
by edtrade 3/11/2011 3:15:35 AM(UTC)
Maytag washer slow spin (Washer Repair)
by Handyman3 1/25/2011 7:14:40 AM(UTC)
3 Pages<123
