Totaleclipse95
#1 Posted : Thursday, April 16, 2009 11:29:15 AM(UTC)
Totaleclipse95
I just received this washer to replace my old one (can not afford a brand new one right now), and I ran a test cycle with it and it worked fine.
I then ran a regular load, and the machine will not stop filling. I have looked online through the wiring diagram, and expected to see some sort of a limit switch to shut the water off at a certain level, but there is no limit switch. So I am assuming that it is all controlled by the selector switch and the air tube that is on the front panel.
Am I correct in assuming replacing the switch will take care of the problem?
#2 Posted : Thursday, April 16, 2009 2:15:18 PM(UTC)
Originally Posted by: Totaleclipse95 Go to Quoted Post
...Am I correct in assuming replacing the switch will take care of the problem?...
Yes you are, but before I would check the pressure hose and its connection the water level switch.
- The part number for the water level switch is AP4026928
Totaleclipse95
#3 Posted : Thursday, April 16, 2009 7:19:39 PM(UTC)
Totaleclipse95
Thanks.
I checked the air tube connection on both the switch end and the tub end, and also checked for cracks or damaged spots. I did find a slight cut in the tube where it leaves the console and goes down to the tub.
I have ordered the switch and the air tube. Thanks for the help
#4 Posted : Thursday, April 16, 2009 7:21:00 PM(UTC)
