Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Very likely the problem is a bad spark module, but the model number you posted does not come up. Verify and repost it please.
Gene. Hi Gene, sorry for the typo. It is JGBP24GEN6AD. If it is the spark module, is it a relatively easy fix? Thank you again for your help!
Originally Posted by: Gene Great job Gene! Quick ordering, module arrived last night and installed this morning! Thank you for your help, Shannon.
You are welcome Shannon. I'm glad it's up and running.
Happy Holidays!
Hi Gene,
I'm new to this site but after reading all your great advice, it seems my stove top might need a new spark module. I have a GE XL44 model number JGBS22BEW3wh. Two of my stove top burners does not click when I turn it on to LITE but I can light it with a match. Is this the right part number for my replacement: AP2020570? My second question is, I think my stove has sealed burners, so how do I replace the spark module because it looks like its located next to clock assembly in the diagram.
Originally Posted by: tylex ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...Two of my stove top burners does not click when I turn it on to LITE... Hello, Would the igniters for these burners spark if you turn on any other burner? Here are the breakdown diagrams and Parts for GE JGBS22BEW3WH Range - AppliancePartsPros.comGene.
The two rear igniters spark and lites. The right front sparks when I turn on the rear but does not spark on its own. The left front doesn't do anything but can be manually lit. What do you think the problem is? Seems like two different issues with the left and right sides. Thanks in advance Gene.
Ty
Hello Ty,
Looks like you have to replace the ignition switches for both front burners as well as the spark module. The bad news is that the ignition switches for this range are no longer available. You still can use it with a matches.
Thanks Gene for all the info. At least I know what the issues are. You guys are running a great forum.
Ty
You are welcome. Sorry we could not really help you this time.
