AppliancePartsPros.com
Appliance Repair Help
Washer Repair
GE Washer grinding noise (not agitator/coupler)
The washer makes this horrible grinding noise, when it tries to agitate or tries to spin.
Fills: Yes Drains: Yes Agitate: No (horrible grindy sound) Spin: No (horrible grindy sound) Coupler: Has all groves and been cleaned or residue Agitator: All material and foreign objects are cleaned and removed from under
Any ideas (on what to do or where to start)?
I added an attachment. When it is on agitation (didn't think to do a spin one), the [COLOR="Green"]green[/COLOR] part kinda (tries) to move clockwise and counterclockwise, in a jerky motion. The [COLOR="Red"]red[/COLOR] parts don't move, but can be manually turned. Sorry if it is upside-down. The photo editing software is horrible.Pure Guava attached the following image(s):
Groups: Expert
Looks like the clip is missing from the motor shaft and the pulley/clutch has dropped. Should look like this. Added: I see the clip laying there, looks like it broke. Here's the replacement. ![UserPostedImage](http://home.comcast.net/~fairbank56/gepulley.jpg) Eric
Originally Posted by: fairbank56 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Looks like the clip is missing from the motor shaft and the pulley/clutch has dropped. Should look like this. Added: I see the clip laying there, looks like it broke. Here's the replacement. Eric The clutch clip was bent out on one end, so I readjusted it and pulled out the little tab in the back/far end which holds it in place and... voila! It works fine! First DIY fix, that could have taken far more time and money, that took less than 10 min! Thanks!!!
Washer Repair
