tangerine30680
#1 Posted : Saturday, January 26, 2013 12:42:38 PM(UTC)
tangerine30680
I have Kenmore model 110.22642100. I have replaced parts 3949238 (lid switch) and 3363394 (pump). I have drained the water from the washer through the tube, so I don't think that a clog is the issue. The washer still agitates but will not drain or spin. I've placed the timer at rinse and there is a ticking sound from the panel. All the forums I've checked state the lid switch, clog or pump could be the issue, but I've had no success with this.:( Some forums suggest the issue could be part 3364003 (motor coupling). I have another suggestion that it could be the panel controls.
Before I purchase any more parts I need to know if this is a panel or motor issue. Thanks.:)
fairbank56
#2 Posted : Saturday, January 26, 2013 1:15:33 PM(UTC)
fairbank56
Groups: Expert
Sounds like the lid switch but you've replaced that. Do you hear the switch click when you close the lid? Does the motor run, just hum or silent during drain/spin?
Eric
tangerine30680
#3 Posted : Saturday, January 26, 2013 1:35:23 PM(UTC)
tangerine30680
Hi fairbank56.:) Replacing the lid switch has the basket turning. The washer is now capable of agitating and spinning but will not drain between the wash and rinse cycle. :confused:
Guest (4)
