Hey guys, just got the new latch with the spacers, but didn't get any instructions on where to install spacers and the ones here are too fuzzy! Where do the spacers exactly go? thanks!
robby101, would it be possible for you to take a picture where you place the spacers? the instructions are hazzy, thank you in advance.
lalberto17 and Rcuadra, Sorry, but I'm out of town until late Sept, so can't send a more clear image of the instructions (or snap photos of my machine) until then. In the meantime, you might be able to get a copy from Sears Parts and Service, which is where I got my copy from. (Ask for Electrolux Service Flash LN0903.)
Thanks to both of you, I really appreciate your info I will try that and go from there!!
thank you robby i can wait so far i was able to do a minor fix and it seems to work, but i will also ask sears.
Rcuadra and lalberto17, (I returned home a few days ago.) Hopefully, this photo of my machine will help.robby1001 attached the following image(s):
Originally Posted by: robby1001  jbkulp, I've attached the first page of Service Flash LN0903. It tells how to remove the top panel, where to place the spacers, etc.. (The other 3 pages tell only how to install the latch itself.) thanks for the info, only place I've been able to find a solution. I can't quite make out the image. I don't know if my model is slightly different, but I can't find the 2 screws. do you happen to have a better image or can someone tell me where to find the screws. thanks
Originally Posted by: msyrjg  thanks for the info, only place I've been able to find a solution. I can't quite make out the image. I don't know if my model is slightly different, but I can't find the 2 screws. do you happen to have a better image or can someone tell me where to find the screws. thanks Hello msyrjg, Sorry to hear you are having any difficulty. I don't have a better image than the one I posted last October. Although that image shows only one of the two screws, the other one is in the 3rd screw hole from the opposite corner. On my washer, those two screws are the only screws on the rear of the top panel and the only screws that hold the panel in place. You won't be able slide the panel forward until you remove them both. Hope this helps.
The plastic piece you spoke of did break and the drawer does not close, but does the latch kit fix a broken drawer or keep a new one from breaking? I don't want to buy a $100 drawer if I can just buy the $10 latch kit!
