3 Pages<123>
tresor
#11 Posted : Thursday, January 24, 2013 3:32:29 PM(UTC)
tresor
hi Gene, We do not have a spanner wrench and were a bit cautious and concerned about trying to use the hammer. The wrench is on order and will arrive in a few days. We did try to spin the agitator by hand, and it turns freely enough. I am assuming that is the same as what was stated in the thread you sent, "If you find the spin basket is tight on the spin tube, then you probably have a failed clutch, just check"
Is that correct?
thank you again for your time & assistance. maria
#12 Posted : Friday, January 25, 2013 5:29:09 PM(UTC)
Hi Maria,
No, it's not the same. The agitator is seating on the transmission shaft and is not attached to the spin tube in any way.
tresor
#13 Posted : Monday, January 28, 2013 9:20:13 AM(UTC)
tresor
hi Gene, We do not have a spanner wrench, already have it on order. We'll check the drive block once it arrives.
fairbank56
#14 Posted : Monday, January 28, 2013 10:35:49 AM(UTC)
fairbank56
Groups: Expert
You don't really need to remove the tub nut to inspect the drive block. Just remove the agitator, thoroughly clean the top of the drive block and agitator shaft so you can see well, and just make sure the tabs on the drive tube are engaged into the slots on the drive block. If the drive block is bad, the inner circumference of it will be worn down so that the slots are no longer there or worn enough that they don't solidly engage the drive tube tabs.
Eric
UserPostedImage
tresor
#15 Posted : Monday, January 28, 2013 1:20:34 PM(UTC)
tresor
hi Eric,
Thank you for your response, it is exactly the type of info we were looking for.
Can you also tell me what to look for on the clutch when we check it? We are planning to do this work on Wednesday and would just like to be armed with as much good information as possible.
Your help is so appreciated.
maria
fairbank56
#16 Posted : Monday, January 28, 2013 2:11:22 PM(UTC)
fairbank56
Groups: Expert
The best way is to observe the clutch hub while the machine is in spin mode. On the typical Whirlpool machine, we remove the cabinet and jump out the lid switch to do this. Iv'e not serviced your particular model and while it's a Whirlpool direct drive design, there are some differences so I'm not sure about removing panels to get to the internals of your machine. Anyway, if your able to gain access and view the clutch hub while it's operating, if you can see that the clutch hub is spinning but the basket is not or is spinning slower than the hub seems to be, then the clutch band which is inside the hub is likely slipping. If the hub is spinning slowly and in synch with the basket, then you have other issues.
Eric
UserPostedImage
tresor
#17 Posted : Monday, January 28, 2013 3:20:33 PM(UTC)
tresor
thank you, Eric, this is extremely helpful!
tresor
#18 Posted : Wednesday, January 30, 2013 8:27:44 AM(UTC)
tresor
We are installing the new clutch. The old clutch has 6 black pads all around and the new one has only 3 whit pads. Is this ok? Seems like the new pads don't slip, but just seems odd. Any info is welcome. The old drive block looked fine.
fairbank56
#19 Posted : Wednesday, January 30, 2013 8:55:24 AM(UTC)
fairbank56
Groups: Expert
Well that's interesting. Those are usually just used in very large capacity washers and yours is a compact one. The 6 pad clutch band is available but I wouldn't worry about it, the 3 pad one is used almost exclusively.
Eric
tresor
#20 Posted : Wednesday, January 30, 2013 9:53:59 AM(UTC)
tresor
We seem to have successfully installed the new clutch BUT now we reassembled all and did a test run with clothes in the machine. When it filled with water, it seemed normal, then when it began to agitate and when it spins there is a loud constant humming buzz that never happened before. Your thoughts? Thank you!
Guest (4)
Slow spin - clicking drum (Washer Repair)
by Machine_Slo 1/6/2020 9:18:40 PM(UTC)
Noise during the fast spin cycle, but not slow spin cycle (Washer Repair)
by onthego4858 6/17/2017 10:18:24 AM(UTC)
Slow spin cycle (Garbage Disposer Repair)
by Cbus 4/26/2016 11:35:11 AM(UTC)
Whirlpool top load very very slow spin (Washer Repair)
by Docken 10/22/2014 5:31:26 PM(UTC)
Intermittent stuck on slow spin (Washer Repair)
by pmhstar 4/28/2014 10:58:36 AM(UTC)
No agitation and clicking during slow spin (Washer Repair)
by Whirlpool ray 12/6/2013 8:54:59 PM(UTC)
Whirlpool top loader slow spin cycle (Washer Repair)
by Re Vera 6/24/2013 12:34:34 PM(UTC)
Intermittent Slow Spin (Washer Repair)
by imageshift 4/2/2013 8:49:27 AM(UTC)
by twg2 4/26/2012 7:40:43 AM(UTC)
No spin or slow spin (Washer Repair)
by Morrisp 10/17/2011 1:02:27 PM(UTC)
slow spin and noisey in rinse cycle (Washer Repair)
by indoorairpro 9/25/2011 8:34:40 AM(UTC)
Leak & Slow Spin (Washer Repair)
by 4evrmoor 4/20/2011 9:14:26 AM(UTC)
Maytag Performa washer, slow spin speed (Washer Repair)
by hank b 4/18/2011 7:26:54 AM(UTC)
by edtrade 3/11/2011 3:15:35 AM(UTC)
Maytag washer slow spin (Washer Repair)
by Handyman3 1/25/2011 7:14:40 AM(UTC)
3 Pages<123>
