3 Pages123>
dchanson55
#1 Posted : 12 years ago
dchanson55
I moved mt GE washer to clean under it. when I went to wash a load it started maikng a bad grinding sound. The washer works fine, just makes the noise. I filled the tub with water for a small load of clothes, ran it with no clothes, and there was no noise. If I press down on the tub and turn the agitator it makes the grinding sound. :(
fairbank56
#2 Posted : 12 years ago
fairbank56
Groups: Expert
Model number?
dchanson55
#3 Posted : 12 years ago
dchanson55
Thank you for your reply will get it in the morning, as it is at another house.
dchanson55
#4 Posted : 12 years ago
dchanson55
Ge model nm WCSR4170G1WW
fairbank56
#5 Posted : 12 years ago
fairbank56
Groups: Expert
The model you have is on the list of models that can suffer from a sagging front apron. If the front apron sags, the support assembly under the tub can drop low enough that the motor pulley and/or the drive pulley will rub on the bottom of the washer. You should be able to see this with the front panel removed. There is a front apron bracket service kit available to fix this problem.
Eric
dchanson55
#6 Posted : 12 years ago
dchanson55
Eric
Thanks Eric, how do I remove the front panel, and could it be anything else?
fairbank56
#7 Posted : 12 years ago
fairbank56
Groups: Expert
Insert a putty knife into the top groove of the front panel in line with the lid opening on each side while pulling outward on the panel. Then just lift the panel off. Observe the pulleys while doing a load to determine if this is the problem. If not, try to localize the source of the noise.
Eric
dchanson55
#8 Posted : 12 years ago
dchanson55
pulled front cover does not look like it is sagging noise is coming from the bottom area where the drive belts are and only with a load of clothes and and water level set for large load
fairbank56
#9 Posted : 12 years ago
fairbank56
Groups: Expert
So, with a full load, you don't see either pulley hitting the bottom of the washer? Can't really help you any further without seeing/hearing it myself. Can you post a video on youtube?
Eric
dchanson55
#10 Posted : 12 years ago
dchanson55
Eric
Yes I can do that, will let you know
3 Pages123>
