jcvencill
#1 Posted : Monday, January 21, 2013 12:28:17 PM(UTC)
jcvencill
The Clock is working and the cook top Nothing else will turn on.
#2 Posted : Tuesday, January 22, 2013 12:16:34 PM(UTC)
Originally Posted by: jcvencill Go to Quoted Post
...Nothing else will turn on...
Can you explain it more detailed please?
What is the serial number of the range?
Here are the breakdown diagrams and Parts for Jenn-Air JES9860AAW Range - AppliancePartsPros.com
Jenn air oven misbehaving (Oven Repair (including Ranges and Cooktops))
by arn09 6/18/2015 11:33:24 AM(UTC)
How to remove a Jenn Air Oven Door and possible Hinge replacement (Oven Repair (including Ranges and Cooktops))
by williefan 11/6/2014 6:52:41 PM(UTC)
Jenn Air OVEN LIGHT WILL NOT SHUT OFF (Oven Repair (including Ranges and Cooktops))
by smylist 9/28/2014 7:52:50 PM(UTC)
Jenn Air oven won't heat all the way (Oven Repair (including Ranges and Cooktops))
by dmd1 1/7/2014 2:50:52 PM(UTC)
Jenn Air oven keep warm setting overheats (Oven Repair (including Ranges and Cooktops))
by scottmt 12/23/2013 1:36:40 PM(UTC)
Jenn Air Oven not heating and light comes on by itself (Oven Repair (including Ranges and Cooktops))
by tdjohnson740 3/29/2012 11:57:07 AM(UTC)
Jenn air oven light won't turn off (Oven Repair (including Ranges and Cooktops))
by janna bestul 3/2/2012 12:29:25 PM(UTC)
Jenn Air oven door does not close all the way (Oven Repair (including Ranges and Cooktops))
by Meyekal 10/4/2011 8:49:54 AM(UTC)
Jenn Air oven fan noise (Oven Repair (including Ranges and Cooktops))
by IreneSN99 1/19/2011 10:41:37 AM(UTC)
Problem with Jenn Air oven (Oven Repair (including Ranges and Cooktops))
by johncher 1/17/2011 12:08:39 PM(UTC)
Jenn Air Oven Display and Controls Broken (Oven Repair (including Ranges and Cooktops))
by nittanykid 12/6/2010 4:32:42 PM(UTC)
Jenn air oven problems (Oven Repair (including Ranges and Cooktops))
by patrickC 8/17/2010 1:20:12 PM(UTC)
1970's Jenn Air Oven - Model Id (Oven Repair (including Ranges and Cooktops))
by dug320 8/7/2010 1:32:26 PM(UTC)
Jenn Air Oven (Oven Repair (including Ranges and Cooktops))
by leej 4/30/2010 8:11:47 AM(UTC)
Jenn air oven no display but works (Oven Repair (including Ranges and Cooktops))
by Gary E 3/30/2010 9:23:50 AM(UTC)
