andyz123
#1 Posted : Sunday, November 4, 2012 9:25:20 AM(UTC)
andyz123
How do we take out the control panel display for our double oven? After removing some screws, it looks like our oven may have the control panel display connected to the oven itself.
Any diagrams or instructions will be most helpful.
#2 Posted : Monday, November 5, 2012 10:03:16 AM(UTC)
Hello,
I hope the instructions attached to the post will help.
Here are the breakdown diagrams and Parts for Whirlpool GBD307PRB01 Wall Oven - AppliancePartsPros.com
beebop
#3 Posted : Wednesday, January 16, 2013 3:29:53 PM(UTC)
beebop
I am having the same problem trying to get to the control board. The oven in the pictures of the above attachment do not match my oven. I read on another forum that the whole oven may need to be pulled out to get the control panel off, can anyone confirm this.
thanks
#4 Posted : Wednesday, January 16, 2013 3:42:02 PM(UTC)
Originally Posted by: beebop Go to Quoted Post
...that the whole oven may need to be pulled out to get the control panel off...
It may help if you will pull the oven out for 10"-12". You don't have to pull it out completely.
beebop
#5 Posted : Thursday, January 17, 2013 5:32:01 AM(UTC)
beebop
For anyone else who may have this oven here are some clarifying steps to get to the control board.
Remove the trim screws and trim
remove screws that hold oven to enclosure(cabinet)
pull oven out a bit (maybe 1/2 inch) and on either side of the control panel are 2 screws that need to be removed, then lift up to get the control panel over the tabs and then outward.
the problem i now run into is that i cannot get the control panel out far enough to disconnect the wires. I am wondering if, like the previous post says, i need to pull the oven out more. Maybe there is a plate on the top that comes off for better access?
beebop attached the following image(s):
#6 Posted : Thursday, January 17, 2013 1:51:34 PM(UTC)
...I am wondering if, like the previous post says, i need to pull the oven out more. Maybe there is a plate on the top that comes off for better access?...
You will never know until you try.
