2 Pages12>
Channon
#1 Posted : Thursday, April 16, 2009 5:55:21 AM(UTC)
Channon
Ok, we are getting a little nuts now, unit still does not cool. Freezer is 40 degrees, refrigerator is 58 degrees. We have throughly cleaned condenser and coils and replaced the defrost heater/thermostat unit which was burned up. There is no longer ice on the coils, the condenser and fan is running but it still will not cool. HELP!!!!!!:mad:
#2 Posted : Thursday, April 16, 2009 6:03:44 AM(UTC)
Check the frost pattern on the evaporator coils.
If it is only frosting up where the freon from the compressor enters the evaporator coils then you may be low on freon.
Here is a good link
http://www.applianceaid.com/refrigerator.html
Check out #20 especially the 3 example pictures part way down the page.
Channon
#3 Posted : Saturday, April 18, 2009 6:19:35 AM(UTC)
Channon
Had the freon checked told us it has 30 lbs. is that good
#4 Posted : Sunday, April 19, 2009 4:19:34 AM(UTC)
Cannot find any info on GE on the net.
It should say on the compressor.
kayakcrzy
#5 Posted : Sunday, April 19, 2009 5:12:23 AM(UTC)
kayakcrzy
Thity pounds, you should have about 7 1/2 ounces. Tom ApplianceEducator.com
Channon
#6 Posted : Sunday, April 19, 2009 6:32:12 AM(UTC)
Channon
Maybe this appliance guy does not know what he is doing, he told me the compressor was out but it runs fine, said he tested the freon and it had 30lbs of freon, but did not find the burned out defrost unit. We ordered a defrost timer in the hopes that it will fix the problem. We are both disabled and cannot afford to replace this refrigerator so any suggestions would be greatly appreciated.
#7 Posted : Sunday, April 19, 2009 7:15:53 AM(UTC)
If there is no ice on the evaporator coils in the freezer section, then you do not have a defrost problem.
Even if the coils were iced up and you manually defrosted the fridge, it would not cause a no cool problem.
If the evaporator coils are clear and the compressor is running you either have a low freon condition or the compressor/sealed system is shot.
Channon
#8 Posted : Sunday, April 19, 2009 8:33:56 AM(UTC)
Channon
The evaporator coils were iced up, we replaced the defrost heater and thermorstat but still not cooling, so we ordered a new defrost timer.
Channon
#9 Posted : Sunday, April 19, 2009 8:35:02 AM(UTC)
Channon
Is there a way to test the compressor?
kayakcrzy
#10 Posted : Monday, April 20, 2009 3:41:34 AM(UTC)
kayakcrzy
I do believe, once you replace the timer, that ought to do it. Make sure you defrost the coil again, after you put in the timer. Tom ApplianceEducator.com
Guest (5)
Clock Timer Driving me crazy! (Oven Repair (including Ranges and Cooktops))
by kmarkowich 4/27/2011 1:31:57 PM(UTC)
my dryer is driving me crazy (Dryer Repair)
by rubywls 11/30/2010 2:27:17 PM(UTC)
Frigidaire Dryer - E68 - DRIVING ME CRAZY!!! (Dryer Repair)
by eciracing 7/8/2010 12:38:49 PM(UTC)
Dishwasher Driving Me Crazy (Dishwasher Repair)
by tucker_jim 2/14/2008 6:18:50 PM(UTC)
2 Pages12>
