I have a Gallery series washer (new in 2005, 13 cycles, two speed motor) that will not fill with enough water to wash large loads of laundry. The model and serial numbers are not legible (they are located on the lid of the washer and have become smudged).
Any suggestions on how to correct this problem?
Check out the tube to the water level switch, and if that is not the problem try changing out the water level switch.
