racefan
#1 Posted : 17 years ago
racefan
I've cleaned the duct work and still no heat. The thermal fuse seems to be located in front of the duct...how do you get to it to replace or to put a meter on it. If the heating element needs to be replaced, which panel do you take apart, top, back, they seem to be spot welded... thanks for your help!
racefan
#2 Posted : 17 years ago
racefan
please reply as soon as possible
Bigboss88
#3 Posted : 17 years ago
Bigboss88
Go to: http://www3.sears.com/
Input your model number. Then select "DRY/CAB HEATER"
It would appear that you will have to remove the drum to access the element.
I believe that you have a broken element.
Thank You
abbie
#4 Posted : 17 years ago
abbie
FIRST check to see if you have the right voltage going to the dryer,There should be 240 volt,s going to the dryer.
Dryer tests good but stil no heat!!! (Dryer Repair)
by Aaron Chesler 9 years ago
No heat!!! (Dryer Repair)
by tdetwiler 10 years ago
Power & continuity but no Heat!! (Oven Repair (including Ranges and Cooktops))
by stockgoblin 12 years ago
New Parts and still no Heat!!!! (Dryer Repair)
by larosa00 13 years ago
No HEAT!!! (Dryer Repair)
by Charley Albert 14 years ago
No heat!!! Please help! (Dryer Repair)
by importtek 14 years ago
i have no heat!!! (Oven Repair (including Ranges and Cooktops))
by timwalls 15 years ago
