angola20
#1 Posted : Friday, January 11, 2013 1:27:49 PM(UTC)
angola20
I have a Maytag electric dryer. When I turn it on, the digital display comes on and works as normal. The heating element and the drum belt work. The dryer works as normal (clock ticks down, sensors detect wetness, etc), except the drum doesn't turn. When I ran the diagnostic test, it told me that the inlet thermistor was faulty. Would this cause the drum to not turn? It seems like that was for the heating element.
Simon / APP Team
#2 Posted : Friday, January 11, 2013 3:47:08 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please check the model number and re post it.
Can you turn the drum manually?
Simon.
angola20
#3 Posted : Friday, January 11, 2013 9:45:07 PM(UTC)
angola20
The correct model number is MED6600TQ0. The drum spins smoothly when pushed manually.
Simon / APP Team
#4 Posted : Sunday, January 13, 2013 1:43:56 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If the motor runs check how the belt is sitting on the drum and arownd the idler pulley. There is the belt tension switch near the idler pulley so when the belt brakes the motor won't turn on.
Here are the breakdown diagrams and 02-Cabinet Parts parts for Maytag MED6600TQ0 - AppliancePartsPros.com
Simon.
