I have a MAYTAG MAV3855AWW washing machine that is spinning slow it also agitates slow.Can someone tell me what’s wrong with it?
Groups: APP Team
Hi. The motor on this washer is reversible. By gliding on the motor plate it's regulating the tension on the belt.More tension - grater the speed. Check both pulleys, belt, drain pump pulley, motor plate. The belt isn't suppose to slip. Here are the breakdown diagrams and 01-Base & Motor parts for Maytag MAV3855AWW - AppliancePartsPros.comPost the results. Simon.
