don_chan
#1 Posted : Saturday, January 5, 2013 6:56:42 PM(UTC)
don_chan
my wall oven gets error code e2f3, when bake is pressed it heats up for a while then switches to broil and locks up. i have replaced heat sensor but issue continues wht else could it be?:confused:
#2 Posted : Sunday, January 6, 2013 1:36:19 AM(UTC)
Parts for Whirlpool GBS307PRB01 Wall Oven - AppliancePartsPros.com
See the attachment for your tech sheet
Odds are that the control board (item 5 in the Control Panel parts) is shot.
Click on the part's picture for more info on it.
File Attachment(s):
GBS307.pdf (399kb) downloaded 4 time(s).
don_chan
#3 Posted : Monday, January 7, 2013 11:43:08 AM(UTC)
don_chan
Originally Posted by: denman Go to Quoted Post
was doing some research while waiting for reply, i came accross the thermostat. is it possible the thermostat could have gone bad....i have had this replaced a couple of years ago
#4 Posted : Monday, January 7, 2013 12:12:38 PM(UTC)
I am not sure I know what you mean by thermostat?
Also I assumed that when you said " heat sensor" that you were referring to the oven sensor.
don_chan
#5 Posted : Monday, January 7, 2013 12:40:28 PM(UTC)
don_chan
yes i did replace heat sensor inside the oven, but there is a thermostat in back of the unit as well just wondering if this could also be the problem
don_chan
#6 Posted : Monday, January 7, 2013 12:41:57 PM(UTC)
don_chan
i think its also called thermal overlod
don_chan
#7 Posted : Monday, January 7, 2013 12:42:28 PM(UTC)
don_chan
i think its also called thermal overload
#8 Posted : Monday, January 7, 2013 5:18:49 PM(UTC)
The thermal overload (thermal fuse) would kill power to the oven elements not lock up the control.
don_chan
#9 Posted : Thursday, January 10, 2013 6:21:03 AM(UTC)
don_chan
ok thank you!
Oven Over Heating (Oven Repair (including Ranges and Cooktops))
by LeesaBennett 5/8/2013 11:43:54 AM(UTC)
Oven over heating and locking door (Oven Repair (including Ranges and Cooktops))
by mfender 1/11/2013 9:47:23 AM(UTC)
Oven over heating (Oven Repair (including Ranges and Cooktops))
by Bob Lewis 11/29/2012 10:03:32 AM(UTC)
oven over heating (Oven Repair (including Ranges and Cooktops))
by greghzl 4/26/2011 1:10:33 PM(UTC)
by pigg74 2/6/2008 6:17:14 PM(UTC)
