I have recently started having this problem, the freezer goes into defrost and stays on too long, I replaced the evaporator fan 6mos ago , and all was fine, then started having probs with icemaker auger freezing and getting stuck, have read several diff post from other members having same issues, there are no missing parts or panels I am at a loss of what it could be , need some expert help, but with the economy the way it is just can't afford appliance repairman right now ,but i've always been a DIY kinda guy, thank you in advance for any response. ROLL TIDE!!
Most probable problem, the evaporator thermistor WR55X10025
