ffizzino
#1 Posted : Tuesday, April 14, 2009 5:16:40 PM(UTC)
ffizzino
Problem: Water getting to door dispenser, but not getting to ice maker, Model IM6.
What I have done:
Changed Water Supply valve-No effect.
Ice maker inlet tube is clear – no ice blocking water flow.
Freezer temperature -100 F
Ice maker light is steady green-not flashing
Feeler arm moves easily back and forth-no apparent problem with spring mechanism.
Freezer door light switch OK. (Water stops flowing to dispenser when door is opened)
Ice maker jump started (turned ice maker off for 30 seconds; Pushed feeler arm back and released 3 times in 15 seconds. No water flow to icemaker.
Any ideas? I am about to give up the fight. Thanks.
#2 Posted : Wednesday, April 15, 2009 2:06:37 PM(UTC)
Swap the wires between the ice maker and the water dispenser coils on the water valve. Push the water dispenser lever and watch if the water will come into the ice maker. Post the results.
P.S. What is the freezer temperature?
Samsung side by side refrigerator No water to ice maker (Refrigerator & Freezer Repair)
by mtrafton 5/29/2020 5:25:03 AM(UTC)
No water to ice maker / water works through door (Refrigerator & Freezer Repair)
by mservice 3/15/2019 4:16:54 PM(UTC)
No water to ice maker or door (Refrigerator & Freezer Repair)
by scar1 1/12/2019 12:49:56 PM(UTC)
No Water To Ice Maker (Refrigerator & Freezer Repair)
by Daussie 6/16/2017 6:42:49 AM(UTC)
by Stone JR 8/21/2016 11:25:13 AM(UTC)
No water dispenses, no water to ice maker (Refrigerator & Freezer Repair)
by jeffreyjd@charter.net 2/5/2013 5:17:45 PM(UTC)
by sydnoid 10/22/2012 6:20:09 PM(UTC)
No Water To ice Maker (Refrigerator & Freezer Repair)
by phuluu 6/7/2012 9:34:28 PM(UTC)
by s_pierce 5/29/2012 9:25:09 AM(UTC)
by barbaraann 3/26/2012 11:36:20 AM(UTC)
No water to Ice Maker or Door Unit (Refrigerator & Freezer Repair)
by Kevin933 11/30/2011 11:44:20 AM(UTC)
No Water to Ice Maker or Water Dispenser (Refrigerator & Freezer Repair)
by JoeSavo 8/8/2011 1:20:18 PM(UTC)
by tkirsch 6/21/2011 10:54:58 AM(UTC)
Frigidaire No water to ice maker (Refrigerator & Freezer Repair)
by taberd1985 6/12/2011 8:23:55 PM(UTC)
by pwg02001 4/22/2011 10:52:31 AM(UTC)
